585,735 active members*
4,871 visitors online*
    Jan 2019
    8
    Dec 2013
    5717
    Re: Types of shaft couplings
    Of the inexpensive choices for small motors I like these couplings https://www.aliexpress.com/item/3286...a-fbc4f205c246
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2003
    24220
    If choosing Helical couplers for servo motors, I would really recommend stainless over aluminum, the latter tend to fail on motors that tend to be on the more powerfull end of the scale.
    Even if using steppers.
    I reserve the aluminum versions for encoder coupling.
    Al.
    Albert E.
    Jan 2018
    1516
    I use the plum ones. I hate the flexibles.
    I've had some dodgy plum couplers sent in the past though.
    Would be nice to have oldham but they cost. You can get the inserts seperately which is handy if you can make your own clamp units.
  1. CNC Shaft Couplings, Whats out there?
    By umfan110 in forum Linear and Rotary Motion
    Last Post: 07-03-2019, 06:42 AM
  2. Taig motor shaft couplings
    By adonai in forum Taig Mills / Lathes
    Last Post: 06-16-2014, 10:35 AM
  3. Helical Beam Shaft Couplings
    By Techbuilder in forum Linear and Rotary Motion
    Last Post: 04-21-2010, 01:12 PM
  4. Flexible Shaft Couplings; where to buy?
    By boyvox in forum DIY CNC Router Table Machines
    Last Post: 04-13-2006, 09:37 PM
  5. Shaft couplings??
    By Lanny in forum DIY CNC Router Table Machines
    Last Post: 07-10-2003, 12:29 PM
