585,761 active members*
4,163 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Advise on 90° corner feed rate adjusment (slow down)
    Oct 2006
    259
    Hi all !
    Hoping one can lead or shed light on how to lower feed rate (adjusting to slow down on approach, then back at reg feed rate once out of corner) on a cut for a 90° corner ( inside cut or outside cut) ( not an arc or radius, on a true 90° sharp corner !!)
    Much appreciate ;0)
    PS....on Mastercam 2017 and on
    Oct 2006
    259
    Re: Advise on 90° corner feed rate adjusment (slow down)
    Any one can come with a solution ..... maybe Superman !!
    PS....maybe a screen shot may shed light on what I'm seeking for :
    Sep 2009
    78
    I'm a NX user and I am unable to reach my MC user colleagues at the moment, sorry! In cam there are typically at least two ways to do manipulate tool loading and a 3rd which includes a 3rd party such as Vericut.
    Some cam software can slow down tool paths by simply analyzing geometry changes with respect to the tool. Another way software can do this is by analyzing the In Process Workpiece (or MC stock model as you know it, I believe) to adjust based on the actual cutting simulation. Lastly, 3rd party solutions such as Vericut can do the latter as well.
    If I get a chance I will run this by my colleagues. They have much more extensive MC than I but in the meantime I would look in your MC settings for something along these lines. By the way I would make use of peel milling if you're using solid tooling for your pocket roughing. If you're using inserted face mills then I highly recommend using corner corner control and the larger the corner smoothing the better. In NX when I have to use face mills I tend to use 12-25% of the cutter dia for my corner smoothing amount; it really helps out a lot to maximize insert life.
    NX 10.0.3
    Dec 2008
    3109
    Quote Originally Posted by Robert M View Post
    The high-speed pocket routine has a feature that places a radius on sharp corner change of directions ... stepover has to be lower (~ 65% or lower, else cusps may remain that need further ops)
    Too large a radius will leave more material in corners <90°
    ie I use about 1-2mm rads when using a 20mm tip cutter in Alum or steel
    If finish contouring into an acute corner.... try cleaning out the corner(remachining) to finish size (or close to it) before running a finishing pass
    Oct 2006
    259
    Thks for....caring & reply, much appreciate your time....
    Wishing all the best, covid free ;0) !!
    Cheers, Robert
  1. Replies: 3
    Last Post: 12-28-2015, 03:05 AM
  2. Multicam feed rate suddenly really slow
    By fender316 in forum Multicam Machines
    Last Post: 08-26-2013, 05:13 PM
  3. Replies: 2
    Last Post: 05-27-2013, 05:05 AM
  4. Feed rate slow down
    By gtdinc in forum Fanuc
    Last Post: 04-30-2011, 11:49 AM
  5. Using G01 alongside G00 (slow feed rate woes)
    By inthezone in forum FeatureCAM CAD/CAM
    Last Post: 08-01-2007, 04:36 AM
