585,759 active members*
4,015 visitors online*
    Jul 2013
    36
    BRIDGEPORT VMC- BOSCH DRIVES-SEM MOTORS
    I have a bridgeport VMC412 with SEM servo motors and BOSCH drives.
    we have had this machine for a good 25 years running. Some years ago I dismantled the Z motor and found the commutator segments paper thin.... I found a sem motor over e-bay and this was not exactly like the one on the machine but ran OK.
    eventually started getting gross positioning error in Z and I reduced the Z max feed in parameters and it cannot go more than F5000. I tried tweaking the bosch control card but cannot get it any better. I need the machine to run faster....but can`t. what are the options? the machine parameters need modifications? I can`t use the motor I have? The machine is still giving out valuable output so worth spending a bit to get it to its original glory.... Any help appreciated.
    Sep 2005
    250
    Re: BRIDGEPORT VMC- BOSCH DRIVES-SEM MOTORS
    Quote Originally Posted by sputnikprec View Post
    The SEM motor on the Z axis should be a MT30M4-24. I don't believe other motors will work.
    Is it possible the new motor has a different encoder resolution? You should ideally find the datasheets for both motors and compare them. Or post them here so somebody can help you.
    You will see that there were many different options for these motors. Mine had a tacho and an encoder. Look on page 3 of this document for instance:
    http://www.callantechnology.com/call...quivelents.pdf
    Take a picture of the nameplates on each motor as a first step....
  1. Bridgeport Series II Interact 2. Bosch Z15-1A-240 motor drives for sale.
    By danande in forum Bridgeport / Hardinge Mills
    Last Post: 04-08-2015, 03:02 PM
  2. BOSCH SERVO DRIVES 050881 Tweaking on BRIDGEPORT VMC INTERACT 308
    By sputnikprec in forum Bridgeport / Hardinge Mills
    Last Post: 10-01-2014, 09:37 PM
  3. Bosch Make Servo Drives
    By M.RISHIKESH in forum News Announcements
    Last Post: 11-17-2011, 03:52 AM
  4. Interact Bosch servo drives for cheap!!!!!!
    By Interact77 in forum Bridgeport / Hardinge Mills
    Last Post: 02-02-2010, 12:29 AM
