586,009 active members*
4,962 visitors online*
IndustryArena Forum > MetalWorking > Diemaking / Diecutting > inserts to machine harden material
    Mar 2008
    375
    I just got some parts heat treated but a am having a tuff time machining the material
    i need to open up the I.D about .020 .
    can you recommend any good inserts?
    thank you
    Dec 2013
    5717
    Re: inserts to machine harden material
    Normally finishing after heat treat is done by grinding or honing.
    Without a lot more information it would be impossible to recommend an insert. I wild guess would be CBN or diamond inserts.
    Jim Dawson
    Sandy, Oregon, USA
    I've machined HRC60 steel using std inserts on several occasions - such as ballnuts, toolholders and pullstuds. The inserts may not last as long as normal but the cost doesn't end up being silly. Some are better suited to interrupted cuts than others, so selection may be sensible in some cases.
    The skill is to run the lathe as fast as you possibly can. That way, the material softens as it cuts, which is the skill of it. It usually burns, too, so make sure there is nothing flammable nearby!
  1. Can Drawing Quality Cold Rolled Steel Age Harden?
    By Proto Stampings in forum Metallurgy
    Last Post: 09-16-2016, 08:31 PM
  2. Plasma cutting harden steel?
    By DavidhCNC in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-29-2015, 06:37 PM
  3. Question about K2 CNC machine material used...
    By MychesterCNC in forum K2CNC
    Last Post: 10-18-2010, 07:50 PM
