585,930 active members*
3,464 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > substitute for rack and pinion for a 4'x4' cnc
Results 1 to 8 of 8
    Nov 2005
    62
    Question substitute for rack and pinion for a 4'x4' cnc
    hello, i was wondering if i could use a roller chaine and sprocket for a substitute for rack and pinion? and how to mount it thanks.
    Aug 2004
    3215
    The problem with a chain is you will not have enought teeth contact and will get alot of slop and backlash in the system.
    Joe
    Mar 2006
    759
    Quote Originally Posted by luther View Post
    These are plasma cutting machines, but it gives you an idea of how it works.
    http://www.cnczone.com/forums/showthread.php?t=16634
    and the last page of Smilewizards' thread,
    http://www.cnczone.com/forums/showth...t=16450&page=7
    I wouldn't say that chain is not an option, if installed correctly I believe you could get most of the slop out.
    Perhaps it is not accurate enough for routing, but I know that it does work well on other machines, especially plasma
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
    Aug 2004
    3215
    Quote Originally Posted by massajamesb View Post
    Yes your thinking is what i was also thinking, but after rereading his post i believe he is talking about using the chain as an actual rack and the sprocket as a pinion.
    Joe
    Mar 2006
    759
    Oh, gotcha.
    You are right about that, Joe. I would not try it (chain) as a rack and gear setup.
    Now, if you were to make the chain taught from one end to the other, and have the driven sprocket on the gantry, with the chain going under an idler, over the drive sprocket, and under another idler, then that might work, but....
    In reality, the cost of chain and sprockets is only a little less (perhaps 50 bucks or so) than using gear rack and spur gear.
    Trust me, I found out the hard way
    -RedGreen show.
    Nov 2005
    62
    hello and yes i was going to use the chain for the rack but now i think i will go with a rack and gear setup. can i used it for a router to? and wnere can i buy a cheap set of rack and gear? thanks
    Aug 2004
    3215
    Aug 2004
    3215
    Look at the Mechmate, Gerald still uses direct drive to it and his resolution is acceptable for his needs, others have geared the motor down, to improve their resolution.
    Joe
  1. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  2. Rack & pinion
    By coolman in forum DIY CNC Router Table Machines
    Last Post: 05-07-2006, 10:14 PM
  3. rack and pinion
    By senor J. in forum Linear and Rotary Motion
    Last Post: 11-17-2005, 11:21 PM
  4. rack and pinion
    By planescott in forum Mechanical Calculations/Engineering Design
    Last Post: 10-11-2005, 09:28 AM
  5. Rack and Pinion
    By Hillman in forum Linear and Rotary Motion
    Last Post: 08-09-2005, 10:14 PM
