PS: All the working area and specifications can be customized according to your requests.
Descriptions Parameters Modle ELECNC-2130ATC Working area 2100x3000x200mm Control system Syntec 6MB control system with 1.8m control box Working Voltage 380V,3phase, 50HZ TOOL Carousel tool changer12pcs Spindle ATC 9.6KW Italy air cooling spindle,HKF 63holder Inverter Taiwan Delta B 11KW inverter Motor and Driver 850W Japan Yaskawa servo motor and servo driver Table surface T-slot and vacuum working table Option automatic labeling machine and printer Lubrication system Auto lubrication system Software Software for nesting and labeling and cabinet making software Others Omron limit switch
Cardiff wire
