586,009 active members*
4,809 visitors online*
IndustryArena Forum > Manufacturing Processes > Drilling > Hi, Need some info.. 1 inch tapping, with BT40 holder?
    Dec 2007
    118
    Hi, Is there anyone tapping 1 inch with BT40 or cat40? Using a Feeler VMC FV-1600 , Meldas 64 control...??
    Dec 2013
    5717
    Re: Hi, Need some info.. 1 inch tapping, with BT40 holder?
    I would not use a tap, requires too much power. I use thread mills. One part I build has a 1-8 threaded hole, 2 inches deep, 6061 aluminum. I do it in one pass with a 2HP spindle.
    Like this one, but with a 1/2 shank https://www.amazon.com/Micro-100-TM-...ustrial&sr=1-2
    Or a multi-cutter type
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2007
    118
    Haha, lol that's me you talked to on the Titan forum...just broke that 600$ Morse tool...now I am scared...I guess I will try again...thanks...any help is much appreciated...
    Dec 2013
    5717
    I thought you might be the same person
    I have used a 1/2 air impact wrench for tapping 1-8, but not recommended for production.
    The good news is that the first tool that I linked to is not $600. It just takes a little longer to thread the hole with the single point.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2020
    7
    Thank you for this useful post!
  1. CAT40 vs BT40 tool holder????
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 01-27-2011, 04:45 PM
