584,874 active members*
5,120 visitors online*
Thread: Feed power
    Feed power
    Hello
    Milling Siemens 840D
    What was the command to limit feed power
    example:
    S444 M3
    G01 X777. F1234
    ???=80 ; max power 80% (normal 100%)
    the feed/power will lower automatically now
    Jan 2019
    Re: Feed power
    G96 S... LIMS=... F... ;Constant cutting speed ON
    G97 ;Constant cutting speed OFF
    S ;Cutting rate, m/min
    LIMS= ;Upper limit speed of the spindle with G96, G97 effective
    F ;Feedrate in mm/rev(G95); in/rev (G94)
