585,715 active members*
3,867 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Need help with steady rest program
Results 1 to 10 of 10
    Apr 2018
    5
    Hi everyone. I've been trying to program to move the steady rest but the M code M58/M59 just don't work in this machine.
    Can you please share your experience programming this?
    TIA
    Feb 2013
    788
    Re: Need help with steady rest program
    Serial number?
    Electrical Edition number?
    Ladder version?
    From that, I can answer anything about why or why not something is happening.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Apr 2018
    5
    Quote Originally Posted by dhardt View Post
    Serial number?
    Ladder version?
    I found this label behind the machine.
    Feb 2013
    788
    Quote Originally Posted by tuantrinh View Post
    That has the machine's serial number. (found on the placard, located near the main power switch)
    That has the Electrical Hardware version. (found on the placard, located near the main power switch)
    What is the ladder version?
    Press the <SYSTEM> hard key
    Press the <PMC> softkey (depending on Fanuc model)
    Press the <PMCPRM> or <PMCCONFIG> (depending on Fanuc model)
    Press the <TITLE> softkey
    There is a field: PROGRAM DRAWING NUMBER (it is in the middle of the page)
    It contains a LONG alphanumeric sequence, separated by a comma or colon...and then another alphanumeric sequence
    I need the WHOLE code...everything in that field.
    From this information, I can see why the machine does anything and everything related to IO
    Feb 2013
    788
    Per your electrical manual:
    The option, if purchased, has a right/left independent open-ability, and a separate m-code to clamp/unclamp its brake bar.
    see the m-code list in the first part of your electrical manual.
    If you want to know the output, and the sequence on actions that enable it, I would need the ladder version.
    Apr 2018
    5
    Thank you for the M code chart. M36-39 work just fine.
    Just one more thing, I need to bypass the chuck and tailstock. I know M31 is the one I need but it doesn’t work. I can’t move the tailstock while spindle running
    Feb 2013
    788
    I NEED THE LADDER VERSION.
    Apr 2018
    5
    Here you go boss
    Feb 2013
    788
    Reply too intricate for simple post of text, see attached
    Attached Files Attached Files
    Feb 2013
    788
    If more information is needed, I recommend that you call my cell number that is listed in my footer.
    (normally use my Office number, but covid-19 has us telecommuting...)
  1. Need a steady rest
    By FUBAR62172 in forum Want To Buy...Need help!
    Last Post: 06-04-2017, 05:09 PM
  2. NEED A STEADY REST
    Last Post: 02-03-2015, 06:14 PM
  3. Steady Rest
    By kstephendaniel in forum Uncategorised MetalWorking Machines
    Last Post: 09-12-2013, 11:53 AM
  4. steady rest rollers
    By mattmazak in forum Want To Buy...Need help!
    Last Post: 01-24-2010, 01:23 PM
  5. TL-2 Steady rest
    By rbest27 in forum Haas Lathes
    Last Post: 04-17-2008, 12:15 PM
