585,997 active members*
4,844 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > Multicam Router MT4872 Lost Servero parameters, Yaskawa SGDH-08AE-S, 2001 year built
Results 1 to 3 of 3
    Oct 2017
    3
    Ser # MT4872601
    History
    The servo amp Yaskswa SGDH-08AE-S, X went down, I fixed it and lost
    the set up parameters so I read them off the Y amp and used them
    not knowing the gear ratio was different I had sat 4:1 and should had
    been 2:1, when I did a reset it did a very hard reset, hit the mechanical stop
    very hard, I changed the ratio and it seem to be ok, I adjusted the resolution
    and it's right, the problem is when I cut a circle it's not round
    see attached #1 the over / under side will change from climb cut to conventional
    cut, I have pulled the X removed the running nut
    cleaned it and checked all the ball bearings. ( Didn't lose any )
    I have no play in my axis and no run out on X or Y.
    I am able to program my servo amps from the front don't have a PC interface cable,
    My biggest help would to find a MT machine that we could read the servo amp setting from.
    Attached #2,3,4 are my servo amp parameters.
    Mar 2008
    683
    Re: Multicam Router MT4872 Lost Servero parameters, Yaskawa SGDH-08AE-S, 2001 year b
    Multicam should have it on record. Another thing to check is make sure your gantry is square.
    Oct 2017
    3
    Quote Originally Posted by warrenb View Post
    Thanks for your reply, Multicam doesn't have that info on file because the lost all of the old set up data a couple years ago when they had a server go down, there MT machines are moving tables that they say can't go out of square, if I cut a square it's square, I believe the problem happens when it's trying to cut arc's .
  1. Yaskawa SGDH Sigma II and Mach3
    By jamesbond007 in forum Servo Motors / Drives
    Last Post: 10-03-2023, 05:21 PM
  2. Camtech Router Master Z7 2001 year model need help programming Inverter
    By higdonsign in forum Drilling- and Milling Machines
    Last Post: 08-01-2017, 08:46 PM
  3. Yaskawa SGMG and SGDH
    By stang623 in forum Servo Motors / Drives
    Last Post: 10-02-2012, 07:40 PM
  4. Yaskawa Servopak SGDH
    By empireweld in forum Servo Motors / Drives
    Last Post: 01-03-2010, 04:44 AM
  5. YASKAWA SGDH-30DE
    By vipinsumitha in forum Servo Drives
    Last Post: 12-07-2009, 03:56 PM
