585,992 active members*
5,672 visitors online*
Results 1 to 11 of 11
    Sick of it all
    I am sick of trying to figure this out! I have an HY-6040 5 axis CNC router. I am using SolidWorks 2018 (no problem), BobCAD V32 (no problem), Mach 3 (BIG PROBLEM)!!!!!!!!! I have reached the point of giving up! I live in Texas in the Kemah area (near Houston). Is there ANYONE who wants to make some money by coming out and helping me configure this crap!
    Re: Sick of it all
    There are loads of knowledgeable Mach 3 users here. What seems to be the issue?
    Also, is it a truly licensed version or a "licensed" version that they send with the machine.
    Re: Sick of it all
    Yes it is a truly licensed version $175.00. As for the problems in no particular order. I can't get the machine limits set. I can't get the home set and I can't get the table limits set.
    Re: Sick of it all
    Do you have home switches?
    Re: Sick of it all
    There are mechanical switches on the X+ & X- Y+ & Y- Z+ & Z- none for A or B
    Re: Sick of it all
    Okay, so you have those registering in Mach 3? And you have their ports and pins correctly set? I assume you are using the limit switches for homing as well?
    Re: Sick of it all
    The short answer is I Don't Know. I have tried to figure it out but have come up short.
    Re: Sick of it all
    Go to the diagnostics page in Mach 3 and see if the limit or home switch LED's light when you work the switches.
    Re: Sick of it all
    They do not.
    Re: Sick of it all
    So, either there is an issue with the connection of those switches, wiring, etc., or the ports and pins are incorrectly set in the inputs page. I'd start by looking at your breakout board, hopefully it has some documentation with it, and determine what ports and pins your switches are connected to. Alternatively, try to find somebody that has the same machine to provide you with their ports and pins setup.
    Mar 2020
    39
    Re: Sick of it all
    Why not try going to ‘ports and pins’ and then ‘inputs’ then use the auto detect option to see if Mach3 can set up your stops. It will ask you to trigger each limit/ home switch you want it to find. This worked for me. I’d do this before looking at your board
  1. sick encoder
    By James-Ross in forum Servo Motors / Drives
    Last Post: 06-01-2019, 09:10 AM
  2. Machine gets sick when it is hot out.
    By Kphurco in forum HURCO
    Last Post: 07-02-2012, 02:37 PM
  3. My Z-axis sounds sick...
    By dbrija in forum Tormach Personal CNC Mill
    Last Post: 03-23-2011, 05:51 AM
  4. My Arrows are sick.
    By advt001 in forum Cincinnati CNC
    Last Post: 06-15-2010, 12:07 AM
  5. SICK and TIRED of SPAM!
    By mxtras in forum Community Club House
    Last Post: 12-04-2006, 08:56 AM
