585,931 active members*
5,100 visitors online*
Thread: Haas VF help
    Mar 2013
    66
    Haas VF help
    After I moved my VFE-0 MILL to my home shop I have been having an issue.
    When the spindle starts with a speed command of 7500rpm, the motor load goes to 100% and stays there for 5-10seconds with spindle running probably 2500rpm, then it will speed up and amps drop to normal level. I have to run my rapids at 25% or put a dwell of 10seconds.
    I have a phase converter, same one I used at last shop. Only thing that changed is my .post . This is a 1997 model. Any suggestions?
    Aug 2009
    1573
    Re: Haas VF help
    How far away is your Service transformer from power company? Wire Size? ...test incoming Voltage when starting spindle. Fadal has a Parm for low voltage...I think
    my two cents,
    DJ
  1. HAAS HA5C on Matusra RA2F - Issues with 2 different HAAS Rotarys/Indexers
    By bjstratton84 in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2016, 04:08 AM
  2. Replies: 2
    Last Post: 04-03-2012, 04:31 PM
  3. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
