585,748 active members*
3,491 visitors online*
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Nov 2015
    33
    Re: Random limit switch false trip
    Hi Jim,
    May have narrowed the issue down to the ethernet connection at the Servo Box. I can create a limit switch trip by wiggling the cables at the box with the Servo powered off. So I am thinking there is a weak connection where the ethernet port is mounted to the board that holds the Gecko. Can't really see in there so I guess I will have to remove them to inspect closely. Anything I should know before doing that?
    Bob
  2. #22
    Dec 2013
    5717
    Good detective work!
    Maybe the socket connection is a bit loose. I have actually gone in with a small hooked probe (bent paper clip?) and bent the the contacts a bit to get a better contact. Over time with vibration the connection can get a bit weak. Also it can oxidize, so reaching in with an emery board and cleaning the contacts can help also.
    Jim Dawson
    Sandy, Oregon, USA
  3. #23
    Nov 2015
    33
    Jim,
    Well I cleaned all the contacts with 2000 grit polishing paper and electronic contact cleaner, reseated all the connections in the Servo.... so far so good. It has been up for 4 hours with no faults. In retrospect, this sort of makes sense thinking about the behavior of the mill, especially when it would trip with the Servo powered off. I will let it idle all day tomorrow just to make sure it is resolved.
    Thanks!
  4. #24
    Apr 2020
    5
    wired switch are actually closed to each other thats why most people dontt notice
  5. #25
    Dec 2013
    5717
    Quote Originally Posted by lumenire View Post
    Jim,
    Thanks!
    My Pleasure :cheers:
    Jim Dawson
    Sandy, Oregon, USA
Page 2 of 2 12
  1. Limit Switch False Triggers - Installing Resistor and Capacitor
    By Jakeller449 in forum DIY CNC Router Table Machines
    Last Post: 02-05-2020, 11:01 PM
  2. False limit switch trigger after replacing router mount
    By wmpinion in forum CNC Machine Related Electronics
    Last Post: 04-04-2019, 10:13 AM
  3. Random e-stop and limit switch UC100
    By rlrhett in forum UCCNC Control Software
    Last Post: 04-27-2018, 02:36 AM
  4. False Limit switch Errors rear's it ugly Head!!!!!!!!
    By Barefootboy4 in forum DIY CNC Router Table Machines
    Last Post: 09-06-2015, 06:06 PM
  5. Limit/Home Switch False Triggers
    By cyberkeith in forum DIY CNC Router Table Machines
    Last Post: 03-13-2015, 02:18 AM
