585,933 active members*
3,619 visitors online*
Thread: DXF Import
Results 1 to 6 of 6
    Apr 2004
    46
    DXF Import
    Ok I know I'm missing somthing but when I import a dxf file and want to extrude the design, what do I have to do to get a surface on the design so that it doesn't look hollow?
    Todd
    Sep 2003
    363
    Look at the shade command.
    103
    Use the join command to make sure the line segments of the .dxf are joined into one curve, then extrude.
    Sep 2003
    363
    Also you may have better luck using Solid-Extrude not Surface-Extrude.
    Apr 2004
    46
    tsalaf,
    I did that and it sill didn't work.
    duluthboat
    Thanks, That's what I was looking for.
    the DXF file could be a polygon model and not nurbs, and thus it wouldn't work, but you can import the curves/polylines then you could extrude them.
    when extruding use the CAP command, look in the command line, this will make its ends cap.
    it would be most helpful to have an image of what your working on.
    you could hit print sceen on the keyboard and then paste the file inside Photoshop. then we could have a good idea of what you have on the screen. Just incase this helps.
    Wyatt Turner
    _______________________
    http://wtdesign.flashex.com/
  1. G-Code to DXF
    By WayneHill in forum OpenSource Software
    Last Post: 05-19-2021, 11:26 PM
  2. jpeg convert to dxf...can I do this?
    By mredican in forum Autodesk
    Last Post: 05-05-2005, 05:32 PM
  3. DXF Catalog
    By CNCdude in forum News Announcements
    Last Post: 08-27-2004, 03:07 AM
