585,973 active members*
4,213 visitors online*
    Cnc auto tool calibration
    Helo
    I have been working with my cnc omi sytec 6mb for a while and everything was ok.but now when it want to mesure the tool on the tool measurement tip My milling machine just goes up ant stops becouse it reaches maximum z axis.So maby someone had a similiar problem when insted of going down to measurre the tool my machine goes up?
    Mar 2020
    27
    Re: Cnc auto tool calibration
    you need to change your calibrator's polarity. I guess your calibrator's signal is on, that's why when you press measure and machine goes up.
    Mar 2020
    27
    Quote Originally Posted by jason-weihong View Post
    Also, you can check your IO board, the calibrator's signal is on. as long as system got this signal, machine goes up.
    Hope this could sovle your problem.
    If sovled, please support WEIHONG controller next time you buy a machine.
  1. Heidenhain M101 - Auto Tool Change If Tool Life Expires
    By Scott_1979 in forum G-Code Programing
    Last Post: 08-21-2018, 03:25 PM
  2. Marlin delta auto calibration issues
    By dangle86 in forum 3D Printing / Scanning Software and Hardware
    Last Post: 10-17-2017, 03:31 AM
  3. Auto tool zero doesn't stop in Auto Tool Zero routine on Mach3
    By Flintstone in forum WoodWorking Topics
    Last Post: 09-05-2017, 07:00 PM
  4. Semi Auto tool setting and Auto xyz
    By shujaa in forum Mach Software (ArtSoft software)
    Last Post: 03-16-2017, 01:29 PM
  5. Mach 3 auto calibration problem
    By jonnyk2 in forum CNC4PC
    Last Post: 01-21-2017, 08:17 PM
