Re: 90vdc supply
Pretty easy to build a power supply that would run all of your motors at full power, but way overkill.
Assuming 240V input
A 5KVA encapsulated 240x480/120x240 transformer. wired for 480V in, and 240V out. Outputs 60VAC. = about 85V DC when rectified.
A 50 amp, 200V bridge rectifier
A 8700uF, 150V capacitor
A 5W, 5000 ohm resistor
Another good option would be 72V, 20 AMP https://www.automationtechnologiesin...vac-or-230vac/ And a heck of a lot less money than the power supply I spec'd above
Having said that, I am running similar motors on my BP clone mill with a single 75V, 5 AMP supply with no problems.
All of the above have a lot of momentary overload capacity. You do not want to use a switching power supply.
For most part your servos will be running at a very small fraction of their rated output.
Jim Dawson
Sandy, Oregon, USA
