585,743 active members*
5,174 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Uneven surface finish on steel
Results 1 to 2 of 2
    Apr 2020
    I was facing a part. But, the surface finish of the part is uneven, only one small part has mirror-like finish and feels 'flat', the other has tool marks. Can anyone explain what could've possibly gone wrong? I'm pretty sure that the part is clamped down hard enough. Hasn't check runout and the inserts have different heights, I used the lowest insert to setup for my z-axis.
    material: mild steel
    tool: 50mm shell mill with 4 AMPT1604 inserts at 90 degree
    speed: 382rpm
    feed: 76mm/min
    DOC: 0.15mm
    stepover: 75% of tool diameter
    coolant: blast
    Thanks.
    Jun 2010
    4256
    Re: Uneven surface finish on steel
    MACHINE????
