585,763 active members*
4,408 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Cannot create work cordinates (G54, G55....) E06 NO SPEC ERROR Meldas 64
Results 1 to 8 of 8
    Jul 2015
    10
    Hello everybody,
    I have cnc milling with meldas 64 control,after loading all the parameters, the machine is working fine but when I'm trying to create the working coordinates (G54, G55....) I get the error: E06 NO SPEC ERROR.
    so please if any one know's how to sort this problem out it will be really appreciated
    thnx in advance for any help!
    Jun 2010
    4256
    Re: Cannot create work cordinates (G54, G55....) E06 NO SPEC ERROR Meldas 64
    Never heard of the brand, but IF Chinese, it is well-known that they do not all support all g-codes.
    Cheers
    Roger
    Aug 2021
    Im having the same issue. Were you able to work it out. I would like to know.
    Cheers Paul
    Jul 2015
    10
    Quote Originally Posted by Moitsea View Post
    Cheers Paul
    I contacted this cnc service from india: https://www.sjautomations.com
    it was a problem of the parameters they helped me to activate them, only the service can activate them. I recommend them with confidence. They did a very good job, on whats app they guided me to activate those parameters.
    15362
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    Mitsubishi Meldas is a quality Machining center
    Mactec54
    15362
    Cheers Paul
    You may find something in this PDF that will solve your problem
    Attached Files Attached Files
    Mactec54
    Aug 2021
    Thanks, will look into it.
    Hi everybody,
    I have cnc milling machine (PINNACLE make VMC with M64 CONTROL) after loading all the parameters, the machine is working properly but when I'm trying to create the working coordinates (G54,G55,G56...) I get the error
    E06 NO SPEC ERROR. So please if any one know's how to rectify this problem.
    With regards
    MAHESH
  1. cannot create G54 cordinates
    By nabil_elbadri in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-05-2020, 09:49 AM
  2. Mitsubishi Meldas 500M RS232 Error P460 TAPE I/O ERROR
    By caduser007 in forum Mitsubishi controls
    Last Post: 01-25-2020, 08:07 PM
  3. Create NC or select tool ERROR
    By forjaco in forum Surfcam
    Last Post: 03-20-2013, 09:29 AM
  4. Create error message
    By ScantraxXRootZ in forum HEIDENHAIN -> MillPlus
    Last Post: 04-06-2011, 12:43 AM
