Hi Tom,
I don't understand why I can't get higher a 'P' value. no matter what i try, it seems that in order to have stability with larger moves, P is going to be around .12 and D is going to be around 90. And I still don't have a good plot. I can move P and D up proportionally above P=1.0, but lose stability on larger moves.
This drive has a feature called Torque Hold, which is activated by jumping terminals 6 & 7 on the drive terminal strip. My understanding is that it overrides the tach signal and puts the drive in torque mode. There is also a feature called External Current Limit. My understanding is that it limits drive current for testing purposes. It is activated by jumping from the drive terminal strip common to terminal 9. Per advise from Mike, the drive specialist, External Current Limit has been active since I had the first problems with the drives. He advised to leave it on until ready to cut chips as a precaution. I ran some tests, all with the same parameters, with various combinations of tach on/off, torque hold on/off, external current limit on/off, and tach terminals jumpered. As expected, it doesn't seem to matter much if the tach is on or off, if the torque hold is on. see notes in plot window for what is on/off.
Plot and Data 28
Attachment 447990
Attachment 447992
Plot and Data 29
Attachment 448004
Attachment 447994
Data 30, Plot in next post, Exceeded file # limit
Attachment 447996
Data 31, Plot in next post, Exceeded file # limit
Attachment 447998
