If I wanted to use Mach 3 with my 6040 sxcnc controller box can I use the UC100??? Pat
Originally Posted by pjf610 If I wanted to use Mach 3 with my 6040 sxcnc controller box can I use the UC100??? Pat Your controller is using step/dir so if it has a parallel port for the UC100 to connect to then there is no reason for it not to work
Mactec54
Thank You Much
View Tag Cloud
Forum Rules
