585,599 active members*
3,563 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > Newbie - Friction Feeder Electronics
    Mar 2020
    Smile Newbie - Friction Feeder Electronics
    I am a newbie on this forum, and in the cnc world. No experience in motors, electronics, PLC, etc. I work in marketing.
    I am trying to build on a T-slot 40x40 and 40x80 aluminium frame, the system that you will find at the 4:14 minute, in the below video:
    https://www.youtube.com/watch?v=Sa5nQ5v9lXc&t=266s
    Pretty much, i am trying to build a Bottom Friction Feeder to move corrugated sheets that are 3000mm in length and 2000mm wide, at about 2,4kg each sheet, which means around 0.400gr/m2.
    My problem is that i don't know the electronic parts that i need for this system to work. I know i need:
    - stepper motors ---> but, which one? (nema 17, 23, etc.) ----> Which motor is strong enough to move 2.4kg of raw sheet?
    - drivers
    - PLC
    - power supply
    - anything else?
    I would need help from someone that knows the exact parts i need to build it, that can tell me "you need this motor, this drive, this plc, etc". I have no idea what i am doing, and the more i search the more i get discouraged.
    Any help, with some links for the exact products, would be really appreciated.
    John
    Dec 2013
    5717
    Re: Newbie - Friction Feeder Electronics
    F=MA, Force = Mass x Acceleration
    Power = Force / Time.
    That is a bit cryptic, but required to calculate the motors required. The mass of the sheets is really a small part of the overall calculation. The mass of the mechanics will far exceed the mass of the sheets.
    If you were feeding one sheet / hour you could use a clock motor, but one sheet / second is going to require a lot more power. The overall system design also enters into the calculation.
    In other words, you have not provided enough information to even make a guess at what is required.
    Jim Dawson
    Sandy, Oregon, USA
