585,978 active members*
4,438 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas VF Toolchanger noise help
    Apr 2020
    Wondering if anyone has any insight on what this might be. Every 4-6 toolchanges, it makes this weird grinding noise. It's very strange that it does it intermittently like that. Here is the video. The first couple tool-changes are normal, then the 3rd tool change you'll hear the noise. I was told it might possibly be a bad pneumatic check valve. Any help is greatly appreciated.
    Jul 2020
    7
    Re: Haas VF Toolchanger noise help
    Did you get this solved?,
    this could be a tool pocket spring error, or a servo error,
    not entirely sure, check your carasual pockets.
  1. 94 Haas VCE 750 / VF-1 z-axis noise
    By ar_cnc in forum Haas Mills
    Last Post: 09-05-2018, 05:24 PM
  2. HAAS OM2A toolchanger Rotation Fault
    By Tungsten808 in forum Haas Mills
    Last Post: 04-26-2016, 11:10 PM
  3. Haas spindle noise
    By Haassucks.com in forum Haas Mills
    Last Post: 07-06-2012, 01:29 PM
  4. Noise in a Haas
    By hall6ppc in forum Haas Mills
    Last Post: 11-04-2010, 05:31 PM
  5. Haas TM-1 Noise level
    By Crash in forum Haas Mills
    Last Post: 06-13-2007, 01:13 AM
