someone can tell me if ive made right choice on settings vfd?
thanks to all
Marco
CHINESE VFD YL620A
SPINDLE 2.2KW WATERCOOLED 220V 8A 400HZ
thanks to all
Marco
CHINESE VFD YL620A
They look ok, you have listed a lot of Parameters they don't all apply to what you are doing but may not affect anything being set Here is a basic list that you can compare with that has worked for other users with this VFD Drive
Have you test run your spindle, make sure the 4th pin Earth/ Ground is connected inside the spindle you can check this with a meter you should have continuity between the 4th pin and the spindle body
Mactec54
Spindle Cable IGUS CF6-15-04 PH 401-438-7270
Huajiang VF Drive
YL 600/620 220 2.2Kw Water Cooled
P00.00=400
P00.01=0
P00.04=400
P00.05=400
P00.06=110%
P00.07=140
P00.08=35%
P00.09=120
P00.10=30%
P01.00=1
P01.03=100%
P01.04=110%
P01.08=110%
P03.08=120
P03.09=400
P06.01=8 ( Acceleration Adjustable )
P06.02=8 ( Deceleration Adjustable )
P0700=400
P07.08=0
P11.01=220 ( May be 2 for 220v )
P11.02=9
P11.03=400
P12.00=9
P12.01=220
P12.02=2
P12.03=6.5
P12.05=10
P12.06=220
Mactec54
thanks mactec , yes with your help no "rattle" sound on spindle , is very silent now , yes its grounded on pin 4
tomorrow i made little adjustement with your settings
thanks again
every one request VFD, can buy here.
http://szkarda.com/en/product/VFD-M-Series.html
