585,991 active members*
5,358 visitors online*
    Dec 2006
    130
    RZNC 501 controller issues
    Hi all,
    been using the RZNC 501 controllers for 3 -4 years.
    Every time i start the new cutting process, the system will automatically goes to SPD GRAD 7, even though during the processing menu, I set it to SPD GRAD 1, it will still runs at SPD GRAD 7 during the cutting process.
    Another question i have: I am using ArtCam. But i cannot seems to set the speed of the milling process using the RZNC controller.
    Example i set 5000rpm on my ARTCAM, but my RZNC 501 controller only seems to runs at the speed set on the RZNC controller. I can only manually set the speed using the RZNC controller during the milling process.
    Thanks, hope you guys can help me in these issues.
    Ivan
    Apr 2005
    304
    Re: RZNC 501 controller issues
    RZNC does not "understand" S parameter in G-Code, it ignores it.
    SPD GradeX is an combination of output levels on 2 pins that are connected to your VFD inputs, and speeds are programmed in VFD.
    So, there is no way to control speed via G-Code, unfortunately.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  1. dsp controller RZNC 0501 software
    By benholvoet in forum Commercial CNC Wood Routers
    Last Post: 09-18-2023, 04:37 PM
  2. Problem with DSP controller RZNC 0501
    By oncoarse in forum Commercial CNC Wood Routers
    Last Post: 01-23-2023, 01:08 AM
  3. Anyone use RZNC A51 controller ? manual jog question
    By mcv in forum Chinese Machines
    Last Post: 09-01-2016, 12:11 PM
  4. rznc dsp controller
    By radicalrescue in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-16-2013, 03:54 AM
  5. Chinese RZNC-05 controller & spindle help?
    By Metalmog in forum Commercial CNC Wood Routers
    Last Post: 05-25-2010, 05:20 AM
