585,604 active members*
3,299 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Tapping with Tension/ Compression Tapping Head with Gibbs
    Aug 2005
    50
    I have an older Anilam Crusader M 3 axis mill. I would like to use a tension/ compression tapping head I have to do several holes in a tooling plate.
    My spindle will reverse using M codes, but the z-axis does not have an encoder for rigid tapping. All the holes will be through holes.
    Should I just use the normal tapping cycle in Gibbscam with the T/C head and set the feed to be a little less than the actual feed of the tap so I get some tension on the tap?
    Thank You for your help,
    Steve
    Jun 2015
    4154
    Re: Tapping with Tension/ Compression Tapping Head with Gibbs
    hy sierevello
    if you alter the feed, then be sure that once the tap reaches the bottom, you won't ruin your toolholder, but still have room available; thus do the math, calculate how much your toolholder will extend, and check if it is actually capable of doing it, but don't go over 80%eq, thus don't use it at the limit
    also, a major factor is how your cnc syncronizes spindle phase and z travel, how much lag is there before reversing, etc ... to reduce all these unknows, use a lower rpm, since higher rpms require more reaction time / kindly
    ps : you said that there is no cycle for rigid tapping, but maybe there is for float tapping ?
  1. DIY Tension/Compression Tapping Head
    By SCzEngrgGroup in forum Novakon
    Last Post: 10-12-2018, 12:08 AM
  2. DIY Tension/Compression Tapping Head
    By SCzEngrgGroup in forum Tormach Personal CNC Mill
    Last Post: 06-09-2017, 07:03 AM
  3. Tension/Compression Tapping Head??
    By Gundawg in forum Tormach Personal CNC Mill
    Last Post: 10-11-2011, 11:29 PM
  4. Procunier tension compression tapping head
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 09-07-2011, 02:58 AM
  5. Reversing Tapping head vs Tension/Compression tapping Head
    By apeman88 in forum Tormach Personal CNC Mill
    Last Post: 01-25-2011, 03:39 PM
