586,013 active members*
4,137 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Post Processor Files > Sheetcam Problem - Mach3 strange artifacts in gcode.
    May 2016
    12
    Lightbulb Sheetcam Problem - Mach3 strange artifacts in gcode.
    I'm trying to test my plasma cutter and having a bit oh trouble with the post processing,
    Could anybody help me by identifying the reason that my post processor keeps putting these circles in my gcode, When I use the simulate in sheet cam it's not there but when I load it into
    Mach3 it then appears, see the picture below...
    I'm running a floating head, and using the mach3 plasma & stencil THC and also the mp1000 THC.
    Code? NO180.....................???
    Re: Sheetcam Problem - Mach3 strange artifacts in gcode.
    Try changing the IJ mode in general config.
    May 2016
    12
    Thanks, im a noob
  1. Mach3 and -gcode problem!!
    By adi7791 in forum Mach Software (ArtSoft software)
    Last Post: 01-06-2018, 09:18 PM
  2. Strange problem with Mach3 and Kflop when using MPG
    By xdmattz in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-02-2017, 12:31 PM
  3. very strange corner problem, mach3 chopping off arc
    By turbocad6 in forum Mach Software (ArtSoft software)
    Last Post: 06-19-2016, 01:34 PM
  4. gcode problem with mach3 (jogging works fine)
    By gurasha in forum Mach Software (ArtSoft software)
    Last Post: 11-12-2014, 01:05 AM
  5. Replies: 2
    Last Post: 07-17-2013, 05:29 PM
