585,555 active members*
3,067 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > micro limit switch cnc what one to buy?
Results 1 to 9 of 9
    Jan 2012
    163
    Looking buy homing / limit switch for PM25-MV CNC mill there are so many anyone can recommend one / witch what one to buy
    Dec 2013
    5717
    Re: micro limit switch cnc what one to buy?
    Most of these would work. Look for slow action rather than snap action. IP67 rating. https://www.automationdirect.com/adc...limit_switches
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2004
    5731
    Non-contact optical switches are supposed to be more accurate than mechanical type switches. This is good when you're also using them for homing; for limits only it doesn't matter much: D5F High-precision Optical Switch/Features | OMRON Industrial Automation
    Andrew Werby
    Website
    Jan 2012
    163
    Quote Originally Posted by awerby View Post
    I wonder what if I was cutting steel and a chip hits the switch?
    Aug 2006
    670
    if you plan on using the switch for home switch as well you'll want something that repeats accuratly. I use these ones on my mill and lathe:
    https://www.automationdirect.com/adc...racy)/css60b-l
    they are a bit pricey, but they are IP65 rated and repeat to .0002". I've been using them for a few years now with no issues.
    Jan 2018
    1516
    I've just taken a chance and ordered some cheap proximity sensors NPN-NO type to have a play with.
    Prob take a week to turn up .
    I bet they'll be crap and be a pita. (hopefully not!)
    24220
    One thing to watch for with proximity version is that they can be tripped by stray chips etc.!
    Al.
    Albert E.
    I've posted my switches here a number of times. They repeat quite nicely (inside my backlash), despite being dirt cheap. Covering the switches and targets is recommended. On long runs where chip build up occurs and the coolant is pumping non stop chips tend to find their way into things that seem impossible to get to. If coolant is a thing on your mill, make sure to get these potted ones.
    https://www.ebay.com/itm/10PCS-TL-Q5...UAAOSwYHxWMdIn
    Nov 2013
    4347
    I use and prefer snap action microswitches for home switches, using these roller plunger switches I obtain 0.02mm repeatability
    without index homing:
    https://nz.element14.com/honeywell/b...ger/dp/1525198
    They have hysteresis which is benficial for home switches.
    Proximity switches are perfectly good for limits but the poorly defined hysteresis counts against them for home switches IMO.
    Craig
  1. MX4660, Home, Limit micro-switch
    By mousepad in forum Electronics
    Last Post: 06-03-2019, 07:25 PM
  2. simple micro limit switch wiring question
    By nateman_doo in forum Benchtop Machines
    Last Post: 12-18-2010, 11:24 PM
  3. MICRO Adjustment of Lever Type Limit Switch
    By scratch_6057 in forum DIY CNC Router Table Machines
    Last Post: 05-16-2007, 02:47 PM
