585,735 active members*
4,733 visitors online*
Page 4 of 4 234
Results 61 to 63 of 63
  1. #61
    Dec 2007
    578
    Re: Rough Finish on 45 Degree wall
    matec45,
    Part looks nice, but cant really tell the finish of angled walls at that distance, but the issue iam having is most noticeable at 45*.
    What size DMMs are you using? What Mode is your drive? And are you using Dynomotion boards?
  2. #62
    15362
    Quote Originally Posted by Need TECH Help! View Post
    matec45,
    750w motors +/- 10 volt analog control, using Dynomotion No, SoftServo control
    I use there Servo's on more than one machine some are step/dir for simplicity with different controls they all work very well
    Mactec54
  3. #63
    May 2012
    537
    Few more pictures of some 1" thick stainless parts I made this week. The center square happened to be orientated at 45 degrees in the drawing so I ran it like that to see what finish would be like. This was with brand new endmill and in stainless so fairly low rpm and therefore lower vibration. I think it was 2500 rpm and 20 ipm. Pretty good results at this speed. If you look really close you can still see slight variation in the interpolation vs straight cuts, but im happy with this as it is.
    Are you still using torque mode? Hows it working?
Page 4 of 4 234
  1. Only MeshCam has option to rough and finish?
    By estes53 in forum Uncategorised CAM Discussion
    Last Post: 07-18-2015, 04:46 AM
  2. VMC Side wall surface finish, Newbie question
    By BlueTwo in forum Uncategorised MetalWorking Machines
    Last Post: 10-07-2011, 10:06 AM
  3. Problems with rough finish
    By 44-henry in forum Tormach Personal CNC Mill
    Last Post: 06-02-2009, 06:43 PM
  4. How to rough/finish threadmill in MCX?
    By John_B in forum Mastercam
    Last Post: 07-27-2008, 04:25 PM
  5. Very rough finish when turning 6061-T6 ... why?
    By cnczoner in forum Uncategorised MetalWorking Machines
    Last Post: 03-16-2008, 11:24 PM
