584,866 active members*
4,991 visitors online*
IndustryArena Forum > MetalWorking Machines > Drilling- and Milling Machines > Heidenhain 426 Cycle 203 drilling Paramater speed redudtion
    Apr 2020
    Hi ,
    does anyone know how to reduce the rapid speed for cycle 203 Universal drilling on a Bridgeport VMC 1000 Heidenhain 426 as its far too quick for what I`m using it for one one offs and not production work.
    Thanks.
    Sep 2009
    99
    Re: Heidenhain 426 Cycle 203 drilling Paramater speed redudtion
    I have three DMU 50 evolutions- two of which have potentiometers on the keyboard to over ride the rapid feed rate. In case if yours does not have this, I would suggest programming a high drilling feed rate and reduce the general feed rate override (which controls both feed and rapid movements - we follow this process on one of the evolutions which doesn't have a separate rapid override)
    I unfortunately do not know how to control the feed rate in the cycle as requested.
    Best regards
    Jaideep
