585,752 active members*
3,944 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Post Processor Issues
    Feb 2010
    12
    Can anyone explain why the post processor would process code like what has been highlighted, and how to correct it? The machine reads the highlighted lines and alarms out because of the "X-.", If I manually edit the program, and remove the "X-.", the machine will read the line without an alarm..
    The post processor i'm using is for Fanuc 16M
    Thanks,
    Andy
    Attachment 441324
    Apr 2004
    5734
    Re: Post Processor Issues
    The machine control is balking because you don't have a value for X. "X-." is an invalid instruction without a number after the point. Are you sure it's the post that's doing that? Have you tried another post, to see if it does the same thing?
    Andrew Werby
    Website
    Feb 2010
    12
    Quote Originally Posted by awerby View Post
    It actually posts out the same no matter what post I use, what I have actually figured out, is that it's posting out "X-." when it should be posting out "X0." and yes, I understand exactly why the control sets an alarm for the"X-." because that command gives no direction, what I don't understand is why "X-." is being posted out rather "X0." like it should be...
    Apr 2004
    5734
    This sounds like an issue for Mecsoft tech support. Send them the file that's provoking this error and let them figure out what's happening. If it's not particular to one post, it might be a bug.
    Andrew Werby
    Website
  1. AXYZ Post Processor Issues
    By Andrew22 in forum Autodesk Post Processors
    Last Post: 12-23-2018, 05:58 PM
  2. UCCNC Post Processor Issues
    By Andrew22 in forum Autodesk CAM
    Last Post: 05-10-2017, 02:55 AM
  3. Post Processor Issues
    By jrmach in forum BobCad-Cam
    Last Post: 10-18-2012, 08:48 PM
  4. Mach 3 and Mastercam X# post processor issues
    By John V in forum Screen Layouts, Post Processors & Misc
    Last Post: 01-10-2012, 07:18 AM
  5. mastercam 13 post processor issues
    By millertyme in forum Post Processors for MC
    Last Post: 01-05-2009, 10:42 PM
