585,991 active members*
6,540 visitors online*
IndustryArena Forum > MetalWorking Machines > Auto Tool Changer > Macro tool change problem meldas64 mitsubishi
    Jul 2015
    10
    The machine is a Lux Mill 650H VMC vertical center and the manufacturer is Twinhorn Taiwan.
    Due to memory loss,I contacted Mitsubishi and they contacted the manufacturer and sent me the parameters and macros for changing the tool.
    I managed to load the parameters with difficulty, the machine works well but does not change the tool.
    I also loaded the macro but I think it's not very accurate (the manufacturer says it can be modified or adapted).
    this is the macro for ATC:
    :9000(20T.MACRO)
    #3003=1
    #3004=3
    G80G40
    N10#100=#4003
    N15#101=#4006
    N20#1100=0
    N21#1101=0
    N22#1102=0
    N23#1103=0
    N24#1104=0
    G91G30Z0.
    N40M19
    N45T#20
    N59IF[#1005EQ1]GOTO120
    N60IF[#1000EQ1]GOTO118
    N61IF[#1001EQ1]GOTO70
    N62IF[#1002EQ1]GOTO117
    N65GOTO59
    N70G91G30Z0.
    M90
    M80
    G04X0.5
    N75#1101=1
    G91G28Z0.
    N77IF[#1004EQ1]GOTO100
    N80IF[#1003EQ1]GOTO90
    N85GOTO77
    N90G91G30Z0.
    M81
    M91
    N95#1103=1
    N98GOTO120
    N100M81
    M91
    N105#1104=1
    G04X0.5
    G91G30Z0.
    M81
    M91
    N115#1102=1
    N116GOTO120
    N117M89
    N118#1100=1
    N120G#100
    G#101
    #3003=0
    #3004=0
    M99
    The tool changer is an umbrella type
    I have attached the picture of the M codes of the machine.
    When I give the command to change the tool, the Z axis comes in position and the spindle is oriented but it stops like this, it does not change the tool.
    Macro stops at N117M89, If I replace M89 with M09 the macro runs to the end but does not change the tool and the Z axis remains in the tool change position.
    Can someone help me? maybe someone has a similar machine...
    Mar 2008
    285
    Re: Macro tool change problem meldas64 mitsubishi
    catana, The M-Code attachment is invalid can you fix it?
