585,589 active members*
3,667 visitors online*
Thread: gcode
    gcode
    hi any good gcode test programmes on here to give my new machine a running in period thanks
    small m/c x750mm y430mm z65mm max travel thanks.
    Sep 2005
    287
    Re: gcode
    What exactly do you want your machine to do to run it in.
    How many times do you want it to do it.
    What feedrate do you want to use.
    When I built my plasma table there was no reason to "run it in", but I did want to check for lost steps after a lot of randon XY moves at rapid speed. All I did was draw a load of zig zaggy lines in cad, and set the table running. My table is 2500 x 1500 so I could fit quite a few lines in, and the test run went for 10 mins.
    Apr 2020
    5
    Re: gcode
    We can't understand your problem. please explain .
    If you want to details knowledge about G - code & operating follow this link - https://www.hdknowledge.com/2017/12/g-code-in-cnc.html
    Re: gcode
    I know someone on the Joe's CNC forum created a Mach3 run in wizard.
    The reason was because they use V bearings on angle iron, and used the run in to "pre-wear" the angle iron.
    There's no need to "run in" a machine built with any standard type of linear motion components.
    Re: gcode
    hi thanks for reply just wanted the machine to run on all axis check the steps
    I have no cad programmes as yet or gcode generators thats my next phase thanks noworries
  1. dxf to gcode
    By Megalos in forum Visual Basic
    Last Post: 08-07-2020, 05:14 AM
  2. Gcode from dxf
    By SPEEDRE in forum Mach Software (ArtSoft software)
    Last Post: 02-11-2014, 07:51 AM
  3. Gcode
    By frankg521 in forum Uncategorised CAM Discussion
    Last Post: 08-01-2007, 06:02 PM
  4. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  5. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
