585,753 active members*
4,400 visitors online*
IndustryArena Forum > MetalWorking Machines > Turning Machines > Turret Problem on Yam CK1 with Fanuc 3T control
    Jul 2013
    9
    Hoping someone can help as I've run out of ideas.
    The turret on my Yam CK1 has an interesting problem in that it works fine if I rotate it with the push button but if I call a tool in MDI or in a program, it will only allow me to do that one time, after which I have to hit the reset on the keypad before it will allow one more tool call. There is no alarm, it just hangs up without accepting to tool call. Each time, it needs to be reset in between tool calls. In a program, the program will hang up at each tool call. I have confirmed that the clamp and unclamp sensor has 24v on it and that they are working. The diagnostics suggest that the problem is in the tool change finish rung but I don't know what to do with that information.
    I have a number of part runs to get out and if i must break the program up at each tool change/bar pull, the time will greatly exceed that time I bid the work for and I will lose my as$.
    Anyone have any suggestions?
    Steven
    Re: Turret Problem on Yam CK1 with Fanuc 3T control
    Quote Originally Posted by triallyr View Post
    Steven
    How about allowing more time for tool change by setting the parameter.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jul 2013
    9
    Quote Originally Posted by cncmakers001 View Post
    I tried this but it didn't make a difference. Thanks for taking the time to offer suggestions!
  1. Replies: 3
    Last Post: 10-06-2019, 01:48 AM
  2. Fanuc 10T Turret Rotation Problem
    By ehsan72 in forum Fanuc
    Last Post: 06-10-2013, 03:14 PM
  3. Replies: 11
    Last Post: 11-01-2012, 10:10 AM
  4. FANUC 6T Turret Problem
    By kulbir in forum Fanuc
    Last Post: 04-14-2010, 08:33 AM
  5. Okuma act 3 with Fanuc 6T turret problem
    By peterson76 in forum Okuma
    Last Post: 08-03-2009, 10:44 AM
