585,567 active members*
3,446 visitors online*
Results 1 to 8 of 8
    Oct 2019
    8
    Maho MH 600E2 tool changer error E185
    Hi everyone, I recently got a maho MH600E2 with 20 magazine tool changer and after a few days of getting used to the controller and the machine, it got stuck on error E185 "Tool in tool gripper". Is there a less intrusive way of getting over this issue other than taking the controller battery out reset?
    Thanks in Advance,
    Abreham
    Re: Maho MH 600E2 tool changer error E185
    Hello ,
    Have you tried M77 from tecah in to reset the tool magazine?
    Oct 2019
    8
    Hi there viorel23cnc,
    Yes i did try that and it returned the tool changer arm to its original position but not the tool gripper ( I think i have read that somewhere where you commented on someone's post).
    Someone also commented about removing the battery and resetting the controller helped.
    I would appreciate any help.
    Thanks in advance.
    Quote Originally Posted by ethiocnc View Post
    Thanks in advance.
    You probably have a sensor problem. It happends with this old machines as they age and after transport. Try to pres the hydraulic valve of the gripper and see if anything changes. If that dosn t work inspect the gripper sensor. It is an inductive type sensor. From the main page of the controller press soft key Dysplay then PLC MON. It will show you all the PLCs proceses. You must identify the bit for the gripper sensor , row and column. I dont know exactly witch one is on my machine but I will check and let you know. Take a copper foil and put it between the sensor and the gripper. See if the bit turns from 1 to 0. If so then probably the loading arm was crashed some time in the past. If not then get an engineer to change the sensor with a new one. As caution you must never work on a toolchanger if M6 is active, because the arm can start moving and hurt you badly.
    Oct 2019
    8
    Quote Originally Posted by viorel23cnc View Post
    Thanks a lot for your input. I'll try that tomorrow and update.
    Cheers,
    Oct 2019
    8
    I'm back again.
    The M77 command did return the arm into position and tool change worked well until returning the arm again an it freezes midway! Even the controller becomes unresponsive so i have to restart the machine and manually return the arm through the solenoids and use M77 command once again to return it to position. This repeats a few times so i stopped it before i damage something out of desperation.
  1. Maho 800C tool changer
    By slider69 in forum Philips
    Last Post: 09-11-2011, 02:51 PM
  2. Maho 600E2 Code 13
    By sts in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 08-31-2011, 08:26 AM
  3. Maho 500 E2 tool changer
    By kesh in forum SERVICE FOR CNC-MACHINES
    Last Post: 08-22-2011, 03:52 PM
  4. Maho 600E2 setup problem
    Last Post: 01-12-2010, 12:55 PM
  5. tool changer error
    By bikebasher in forum Fanuc
    Last Post: 04-28-2009, 10:25 PM
