585,930 active members*
3,918 visitors online*
    CNC Router - Frame Structure
    Hi all,
    I have purchased a new CNC-Router with clamping area of 1730x890mm (weight: 82 kg - picture attached) , and I was wondering what do you recommend to use as the "structure" or table. What is the normal way to use this kind of CNC-Routers? Does it work well on top of a standard table, or is it better to have a stainless steel structure?
    Many thanks
    15362
    Re: CNC Router - Frame Structure
    Quote Originally Posted by gmoreno_cnc View Post
    Hi all,
    Many thanks
    Some build a wooden table to support there machines needs to be quite solid though, a steel frame is always going to be best but needs to be well built also, stainless steel material is not needed but if it is at a good price then why not
    Mactec54
    Dec 2003
    1222
    As long as the table is solid and it holds the machine level it shouldn't make a huge difference what the material is.All he cutting forces are contained by the machine itself but you will need a bit of diagonal bracing to reduce the vibrations in response to movement of the gantry as any oscillations could combine with the harmonics of the gantry with extreme accelerations or decelerations.Stainless would work well but you would need to find an amazing deal given how inexpensive steel is.
    35538
    With a machine like that, the table really adds nothing to the machine. Any flat surface that will hold it still will be fine.
  1. Disassembled structure for cnc router
    By linda_roctech in forum Roctech CNC Routers
    Last Post: 12-29-2014, 08:56 AM
  2. WOOD CNC ROUTER structure
    By Morntech2008 in forum OneCNC
    Last Post: 11-21-2014, 10:59 AM
  3. Design and build of a metal structure 3 axis CNC router.
    By kostix777 in forum DIY CNC Router Table Machines
    Last Post: 08-16-2011, 06:20 PM
  4. new ATC CNC Router with outstanding structure
    By limacchina in forum News Announcements
    Last Post: 02-16-2011, 09:12 AM
  5. Router Structure
    By One of Many in forum DIY CNC Router Table Machines
    Last Post: 01-29-2007, 04:08 PM
