585,987 active members*
4,372 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How do I make the dotted lines sync with the green curve?
    May 2020
    Angry How do I make the dotted lines sync with the green curve?
    Hi, I've just started Mastercam 2019. Right now I am having an issue with plunging(or it may be). Does anyone here knows how to perfectly sync the dotted lines with the green tool path( or I hope that it is a tool path)?
    Dec 2008
    3109
    Re: How do I make the dotted lines sync with the green curve?
    The 2 ways to "sync" the items
    1.. is to have a zero radius on the tool... (not practicable)
    2.. have cutter comp applied to the path... (additional problems will develop)
    There is no problem with what you currently have... it is showing the adjusted path of the tool with nose radius to give a correct shape..
    the path shown is of a sharp (non-radiused) tool, that has the nose radius touching the contour.
    You mentioned plunging... direction &/or distance can be adjusted with the "lead in/out" settings.... in conjunction with what geometry is selected.
  1. Make a green laser pointer more powerful
    By michale in forum Commercial Laser
    Last Post: 03-15-2017, 03:23 PM
  2. curve fit, simple splines, reduce lines and arcs geometries for cutting
    By cutleader in forum Uncategorised CAM Discussion
    Last Post: 09-01-2016, 08:03 AM
  3. WoodWop 5 Multiple Lines to Arc/Curve
    By Ezzy in forum Uncategorised CAD Discussion
    Last Post: 06-10-2016, 08:23 AM
  4. screen display is full of green lines
    By jpluck in forum Milltronics
    Last Post: 12-22-2011, 09:31 PM
  5. TurboCADCAM 12 missing green removal lines
    By MechWerks in forum Uncategorised CAM Discussion
    Last Post: 10-06-2008, 04:01 PM
