Does anyone no how to config an aggregate (see photo). Its to go in a 4th axis Biese 322. The config should be the same for any CNI controlled Biesse.
You'll need to find out which Aggregate number it is, then select that in the aggregates window, then define the correct parameters which will be slightly different to what is already preset in each field.
This is the aggregate PDF.
Thanks for PDF. It looks like the nearest equivalent is 22. I have managed to sort out the Gcode. I am just not certain on the Configuring the machine for an aggregate. Have you setup an aggregate yourself, and would it be possible to show your setup screens?
