I have a Bridgeport mill with Anilam 1400M control which I have been working on for the last 3-4 weeks. I have traced all the wiring in the computer cabinet and power panel on the side of the mill which is back to spec according to the schematics given to me by Jerry. Originally my problem was the head would not rotate which was traced to a malfunction in the overload relay. That problem fixed.
I recently disconnected the Y axis servo for cleaning, and when I replaced the cable and activated the servo it took off rapidly like a bat out of hell; if it wasn't for the limit switch I would have had a mill table on the floor. So I disconnected it again after attempting to balance, without any luck. I then disconnected the X axis which was working perfect and connected the Y axis to the X to see if the problem went to the X axis (It did not). Now the X axis took off after I turned it back on, thank God for limit switch, and i cant get either axis back to operating properly. The Y slowly turns as if it needs to be balanced but doesn't react to balance adjustments. Y rotation will speed up or reverse if I jog +/- on the control. X axis will react to balancing but just rotates the opposite way. I did some cleaning with electrical cleaner, and alcohol: still no better. Y doesn't move at all, and X runs like a scalded dog who's tail is on fire...both axis will count +/- so I don't believe it's the encoder, and the servos operated just fine last week. I get no signal on the Y to balance and I can't get X to slow down when trying to balance.
Anyone with Anilam control have experience with this problem? I'm running out of ideas and am starting to dream about large quantities of Tannerite, but I'd really like to have a machine at home so I could make s**t I want.
