585,715 active members*
3,947 visitors online*
Results 1 to 9 of 9
    BriteHarry Guest
    Software for engraving
    Hi people,
    I need a couple of basic words like "left" "right" etc engraved into some aluminum about 0.015" deep using a 1/8"dia d-bit 60deg cutter.
    Does anyone know of some free or low-cost software I can get that will generate the toolpath or a dxf file? Once I have the words I need in gcode or dxf I will not need the software again.
    I tried DeskEngrave, but it does it in a million little steps and it also has some overlapping lines when generating the text.
    Apr 2003
    1876
    You could long hand it in about 2.34 minutes.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Apr 2003
    550
    Desk Engrave is totally free and will generate the gcode for this with no problem. Just do a search it with Desk Nc and other software from the same guy.
    2139
    Just draw the letters in a cad program the hard way? That or use text in autocad and explode it with the express tools text explode tool.
    Eric
    I wish it wouldn't crash.
    Apr 2003
    416
    If you have Autocad, do what balsaman said. Type the text, explode it. (use a shx font)
    Then convert the exploded lines to polylines.
    You can then export the gcode using ger21's gcode exporter or my gcodeout. (both free downloads in autocad forum here in cnczone)
    Bill
    Apr 2003
    1079
    Is there a something similar that will create 3d toolpaths for varied-depth text?
    270
    Vfontz, but you will need Vector-cam to process the toolpaths.
    http://www.vectorcam.com/abcv1.jpg
    Info Here:
    http://www.vectorcam.com/vfontzt.html
    Fred Smith - IMService
    Sep 2003
    111
    VS3D can do varied-depth text and general 3D relief surface sculpting (and can output the necessary tool paths in G-code and other formats). VS3D handles true-type fonts and can do raised lettering (cut away the background and leave the letters raised above it). VS3D's home page is at:
    http://www.DesignsComputed.com/vs3d
    Daniel Carr - President,
    Designs Computed, LLC
  1. Engraving Software
    By The Wizard in forum Uncategorised CAM Discussion
    Last Post: 03-29-2005, 12:38 PM
  2. Software sales or "license transfers"
    By metlmunchr in forum BobCad-Cam
    Last Post: 07-05-2004, 10:47 PM
  3. ***One stop CNC software guide***
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 05-27-2004, 10:31 PM
  4. What software are you using?
    By BeerFizz in forum DIY CNC Router Table Machines
    Last Post: 12-06-2003, 10:15 PM
