585,991 active members*
4,604 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > DECKEL MAHO / DMU 50V 5 axis / MillPlus V310 / IDE HDD Image file wants
Results 1 to 10 of 10
    Mar 2008
    34
    Hello Guys,
    I'm just bought DMU 50V 5 axis MillPlus V310. Unfortunately, IDE HDD is faulty and the machine can not boot up the system.
    I'm looking any one can help for HDD Ghost for this machine. Sure, I can pay for image file.
    Best Regards,
    INUC
    Sep 2009
    99
    Re: DECKEL MAHO / DMU 50V 5 axis / MillPlus V310 / IDE HDD Image file wants
    Do you have the Heidenhain ID Nr for the disk? That might be helpful for people to check. There are a few sellers on ebay offering this btw- you might be keen on checking there
    Mar 2008
    34
    I'm not sure it is right whether or not . I asked DMGMORI, they told me that this controller is not Heidenhain (But Heidenhain had took over them). It is Philips or Grundig / Model : PG1220 Series, they also not much information about this controller. There is yellow sticker put on the Toshiba IDE HDD " AE374040-567 " only. DMGMORI can supply this HDD+OS but they quoted terrible price for USD 3,400.
    Oct 2018
    11
    Hi, the OS is only available from DMGMori, there are a number versions, once you fit the disk, you then have to rebuild the parameters from a backup. I do these in the uk and it is not something I would recommend doing remotely. Sorry mate but see if you can negotiate a better price with Dmg bet the control working and then get a full backup.
    Br
    Nov 2018
    5
    Quote Originally Posted by iNUC View Post
    Hello Guys,
    Best Regards,
    INUC
    Hi,I have dmu50v with millplus v310.
    I can try to send you a copy of my hard disk
    Mar 2022
    Hello. There is a DMU 50 V machine with a problem. After loading the control program, error 208 appears. The hard disk test showed that there are no problems. Maybe someone and you have a hard disk image for this machine. Thank you in advance.
    are have finish it ,,, email me : [email protected] may be I can help you...
    Feb 2023
    Hello
    Does anyone have a BIOS photo of a 1996 DMU 50V working machine, Philips PG1220 Series, Grundig Millplus control, 5 axes. Interested settings:
    1. Submenu "Memory Shadow"
    2. BIOS Embedded Extension Configuration BIOS Extension Base Address
    3. EXM menu
    My e-mail: [email protected]
    Thank you very much.
    Sep 2019
    11
    Looking for hard drive copy for V320. I sold the machine to a customer and the hard drive cave out a week later. We haven't finalized the deal yet so I need to fix the machine still to get payment. since I promised to get it up and running and train the staff.
    Sep 2019
    11
    I managed to solve the E252 error.
    I turned the machine on and press delete.
    Then heidenhain numeric service menu appeared.
    From there i selected 6. Load default machine constants and clear all memories.
    After I needed to import all machine parameters.
  1. Deckel maho 80U (1999) millplus E252 error
    By swedish steel in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-15-2023, 11:21 AM
  2. Deckel Maho - DMC 63V Z axis drop
    By atultapkirkar in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 04-07-2022, 05:41 PM
  3. Deckel Maho DMU 50 eVolution - Heidenhain Millplus
    By sandeepmb123 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-26-2021, 07:58 PM
  4. Deckel Maho DMU 50 MillPlus errors , needed Help
    By blasterpl in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-02-2016, 09:12 AM
  5. Deckel Maho DMG DMF 250 Linear 4 axis VMC
    By powerstream in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-24-2015, 01:52 AM
