585,556 active members*
3,598 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > No LIM status. Unable to troubleshoot limit switches
Results 1 to 6 of 6
    Oct 2006
    5
    Hello there.
    I am using Arduino UNO , GRBL 1.1h and CNC shield on small desktop CNC. I am trying to troubleshoot limit switches but cannot get LIM output on terminal staus string . Here are settings
    $0=10
    $1=25
    $2=0
    $3=7
    $4=0
    $5=0
    $6=0
    $10=19
    $11=0.010
    $12=0.002
    $13=0
    $20=0
    $21=0
    $22=1
    $23=3
    $24=25.000
    $25=500.000
    $26=250
    $27=1.000
    $30=1000
    $31=0
    $32=0
    $100=23.500
    $101=50.000
    $102=400.000
    $110=200.000
    $111=200.000
    $112=200.000
    $120=10.000
    $121=10.000
    $122=10.000
    $130=200.000
    $131=120.000
    $132=50.000
    ok
    $10 is set to 19 , as per recommendations from public forums, but whatever I am doing I can't see any status in the output.
    I am using TerraTerm at this point to communicate with GRBL
    typical output is like that
    ?<Alarm|MPos:0.000,0.000,0.000|Bf:15,128|FS:0,0>
    ?<Alarm|MPos:0.000,0.000,0.000|Bf:15,128|FS:0,0|WC O:0.000,-1.000,0.000>
    ?<Alarm|MPos:0.000,0.000,0.000|Bf:15,128|FS:0,0|Ov :100,100,100>
    Any ideas, folks? Any help wil lbe gratly apreciated
    Mar 2015
    409
    Re: No LIM status. Unable to troubleshoot limit switches
    To enable the limit switches do the following:
    • Enable hardware limits (set $21 to 1)
    • For normally open sensors (NO) set $5 to 0
    • For normally closed sensors (NC) set $5 to 1 and connect the X-limit and Z-limit pin to GND, if there are no limit switches connected to them.
    Oct 2006
    5
    Thanks. Switches (HW micro switches - NO ) itself are connected to the shield, I just did as you recommended, but still see no LIM output in the status line.
    Mar 2015
    409
    What CNC shield are you using?
    Oct 2006
    5
    Something like that "CNC Shield Expansion Board V3.0+UNO R3 Board with usb for Arduino+4pcs Stepper Motor Driver A4988 Kits for Arduino" I bought this from eBay a while ago. Do you think this is shield issue?
    Mar 2015
    409
    Could be, a RAMPS shield doesn't support hardware limits due to the pin mapping RAMPS choozed. I have a (2) Keyes Uno cnc shield where the step and enable pins are swapped, etc.
    If you have programmed the arduino uno your self, you had to chooze the right grbl version.
    Save your grbl configuration and try this one. It comes from an arduino uno that uses hardware limits (lathe). Ignore the errors you see, they are caused because this is a GRBL-L configuration file.
    If that doesn't help, remove a limit switch and simulate the switch by connecting the limit switch input to GND
  1. Replies: 0
    Last Post: 04-08-2020, 03:52 PM
  2. G540 Limit Switch issue, no Limit Switches fitted!
    By Imagineering in forum Gecko Drives
    Last Post: 09-22-2017, 08:21 AM
  3. Replies: 3
    Last Post: 11-05-2013, 02:54 AM
  4. E-Stop,Limit Switches - Car door open switches ?
    By TrickyCNC in forum DIY CNC Router Table Machines
    Last Post: 04-19-2012, 09:55 PM
  5. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
