585,763 active members*
4,132 visitors online*
IndustryArena Forum > Manufacturing Processes > Other Manufacturing Processes > What machine cutting area suits you best?
    Apr 2020
    16
    Question What machine cutting area suits you best?
    What cutting area suits your needs and space best.?
    This can be either a Router or Mill type machine. So here's a few questions.
    #1 Machine type, Mill or Router (no lathes)
    #2 Cutting area X, Y, Z
    #3 Ideal overall footprint size W,D,H (or space to fit into)
    #4 Floor standing or benchtop.
    #5 Material most likely to be cut.
    Thanks.
    Dec 2013
    5717
    Re: What machine cutting area suits you best?
    That's a pretty open ended question given that everyone's needs are different.
    For my purposes:
    #1 Mill
    #2 about 40x14x18 inches
    #3 I have plenty of shop space, so a full enclosure for flood coolant. Footprint about 10x7x8 feet
    #4 Definitely floor standing
    #5 Mostly aluminum, some plastic, and stainless steel.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2008
    683
    The one I don't have when I need that extra inch or two!
    Jun 2015
    4154
    hello, i just discovered this thread like someone said : ' always one size too small '
    sometimes it may be needed just a bit of more travel, and that may be solved by using a custom tool&holder
    maybe is needed to modify the tailstock as a steady rest, remove the right cover, and voila, you can rough longer parts
    put a big orizontal 4th axis inside a vmc, and voila, you can mill a bigger part, by indexing the rotary axis
    a while ago we discused the option to machine a bigger part on a cnc lathe, by raising the spindle using a cast iron plate
    today we discused the option to machine a huge size part by using an horizontal rotary axis ( comanded from the mill ) near the lathe, using the y turret in an interpolated manned, because it is not vertical; even more intersting if we could use the rotary axis vertical, thus using the cnc turret to cut on a part that is not rotated by main spindle .... oh, i almost forgot, also today we discussed about using a more powerfull part ejector inside the 2nd spindle, that should eject the parts directly to the customer door
    things can be done, especially if there are veterans ( machine level +5000 experience ) in your shop there are also others that prefer to get their nails done, so ...
    if you wish, check this video :
    Pushing the Okuma to the Limit - The Set Up. - YouTube
