585,754 active members*
3,915 visitors online*
Page 2 of 3 123
Results 21 to 40 of 46
  1. #21
    Nov 2015
    260
    Re: Independent PWM signal output
    Hello.
    I have now programmed an Arduino that makes the 0-5v signal in Pul and dir signals for a stepper motor.
    Now I can regulate the pump for my minimum amount of cooling via the GUI.
    It would be nice to have a slider like the speed and feed override.
    Is there another way to display the current status of the PWM signal? (Apart from the red / green lights)?
  2. #22
    Jun 2017
    143
    This sounds cool, but I personally would have used I2C to talk to the Arduino as you could then just send exact numbers that would give more precise control and more likely a larger range of speeds. I control my spindle doing something like this as I found the analog output from the board not to be vary accurate, but also my spindle didn't respond in a linear way and was often out by 5-10%. I now use I2C to a small board that talks RS485 to the VFD and it is now exact.
  3. #23
    Mar 2017
    1304
    USB communication with external hardware is powerful and very useful thing.
    Unless I have simple modules I prefer to use it. This way I can implement all logic in MCU.
    Regarding sliders. I attached Btn file with some interesting examples. I'm sure you'll find it uswful.
  4. #24
    Nov 2015
    260
    Quote Originally Posted by PlanetCNC View Post
    Hello.
    Thanks for the answer.
    I already have the attached buttons.
    But there was once talk of a slider.
    I have no way of comfortably seeing which value is set.
  5. #25
    Nov 2015
    260
    Yes, I also considered this type of communication. But I am not informed enough for that.
    Would you like to explain your path in more detail?
    I didn't get along with the spindle setting either. The deviations are considerable. I made the settings according to the manual. And it just doesn't fit.
  6. #26
    Mar 2017
    1304
    1. There are couple of examples with Arduino included in API folder
    2. Button with menu is not enough? See image.
    3. You can display your value in state panels as a number.
  7. #27
    Nov 2015
    260
    Yes, I tried that. But I don't get any further.
    How can I display this. What code am I going to write the stade1.txt file?
  8. #28
    Nov 2015
    260
    I followed the following tutorial.
    But I can't find the parameter to display the PWM signal anywhere, not even in the Doko PDFs.
    In addition, I would like to only display certain LEDs of the inputs and outputs. So e.g. only LED from input 1 and 2.
    https://planet-cnc.com/create-custom...-tng-software/
  9. #29
    Nov 2015
    260
    No ideas?
  10. #30
    Mar 2017
    1304
    Sample folder contains StatePanels with state panels examples. Most of parameters are included.
  11. #31
    Nov 2015
    260
    How can I do that. Which parameters do I have to enter. The state.txt files in the Sampels folder do not help me because this example is not available there.
    Also on my second question how I can only display a single LED of the output / input / limit, I can't find it there.
  12. #32
    Nov 2015
    260
    [QUOTE=tantemay;2414856... Also on my second question how I can only display a single LED of the output / input / limit, I can't find it there.[/QUOTE]
    OK. Find it.
  13. #33
    Nov 2015
    260
    After a long search I have now found it. But I'm still looking for a way to display a single PWM LED.
  14. #34
    Nov 2015
    260
    Code:
    param _hw_output_duty1 0 "MMS-Level:"
    How do I have to change the code so that the displayed value is divided by 50?
  15. #35
    Mar 2017
    1304
    expr: "res = _hw_output_duty1 / 50" 1 "My Value"
  16. #36
    Nov 2015
    260
    Do not work.
    I don't mean in the Bnt.txt, I mean the State.txt file.
    Attached Files Attached Files
  17. #37
    Mar 2017
    1304
    use expr without ":"
    expr "res = _hw_output_duty1 / 50" 1 "My Value"
  18. #38
    Nov 2015
    260
    Thanks that works fine.
    I have one more question about the buttons.
    Is it possible to make a button that increases the current value of the PWM signal each time it is pressed?
  19. #39
    Jun 2017
    15
    Quote Originally Posted by theRat View Post
    would you mind detailing how you did this to control your spindle speeds?
  20. #40
    Jun 2017
    143
    Quote Originally Posted by mharter11 View Post
    Sorry for the slow reply, I have been in hospital to have a hip replaced.
    The general concept is to have an atmel microcontroller (I used a ATTiny1614) connected to the Mk3/4 SD&I2C header. The circuit also has a SN6517B rs485 transceiver connected to a USART on the ATTiny and then off to the RS485 pins on the VFD over a twisted pair cable.
    For the software on the ATTiny I originally implemented all the commands needed to control a NowForever vfd, which kept the M3/4/5 scripts quite straightforward, but the problem with this was that if it was to be used for another brand of vfd the ATTiny would need new code. So I have since changed it so that the ATTiny only does the comms and has no idea about the required protocol and now the Plantet CNC scripts deal with the protocol. This means that the code on the ATTiny doesn't need to change to implement controlling different vfd's, just new scripts.
    The board I designed also has a TCA9535 on it (I2C expander) to allow for control of up to 16 relays (my board has 4 on it, and drivers for 2 off board relays).
    So for me now I have a bunch of scripts to help with turning the spindle on/off and controlling the speed. This is part of what I have for controlling my NowForever VFD.
    M3.gcode
    Code:
    ;set spindle speedO<SetSpindleSpeed> call
    ;turn on spindle pump
    #<_i2c_output_0> = OR[#<_i2c_output_0>,#<_coolant_pump>]
    O<SetI2COutput0> call
    ;run forward
    O<SetSpindleRun> call [1]
    O<PlanetCNC> if [#<_spindle_delay_start> GT 0]
      O<Delay> if [#<_spindlespeed> GT 18000]
        G04 P[#<_spindle_delay_start>*2]
      O<Delay> elseif [#<_spindlespeed> GT 12000]
        G04 P[#<_spindle_delay_start>*1.5]
      O<Delay> else
        G04 P#<_spindle_delay_start>
      O<Delay> endif
    O<PlanetCNC> endif
    M3
    SetSpindleSpeed.sub
    Code:
    ;Control NOWFOREVER spindle speed
    O<SetSpindleSpeed> sub
        ;fill buffer with parameters to set spindle speed
        #<speed_lo> = SHR[[#<_spindlespeed>*100/60],8]
        #<speed_hi> = AND[[#<_spindlespeed>*100/60],255]
        (array,4000,1,#<_vfd_addr>,16,9,1,0,1,2,#<speed_lo>,#<speed_hi>)
        O<Crc16> call [4002] [#4000-1]
        #<crc> = [#<_return>]
        O<test> if [EXISTS[#<_rs485_debug>]]
            (print,crc=#<crc,0>)
        O<test> endif
        ;add the crc16 value to the end of the buffer
        #[4001+#4000] = AND[#<crc>,255]
        #[4002+#4000] = SHR[#<crc>,8]
        #4000 = [#4000+2]
      ;print request buffer if debug is on
            #<size> = [#4000]
            (print,Request Size=#<size,0>)
            #<i> = 0
            O<print1> repeat [#4000]
                #<q> = [#[4001+#<i>]]
                (print,#<q,0>)
                #<i> = [#<i>+1]
            O<print1> endrepeat
        O<test> endif
        ;zero the return count and send the buffer to the i2c bus
        #<count> = 0
        O<loop1> do
            #<err> = 0
            #4100 = 0
            M66 H38 Q4001 E#4000 R4100 D4 ;set the spindle speed
                #<size> = [#4100]
                (print,Response Size=#<size,0>)
                #<i> = 0
                O<print1> repeat [#4100]
                    #<q> = [#[4101+#<i>]]
                    (print,#<q,0>)
                    #<i> = [#<i>+1]
                O<print1> endrepeat
            O<test> endif
            #<count> = [#<count>+1]
            O<error1> if [ACTIVE[] AND [#4100 NE 3]]
                O<test1> if [#<count EQ 5]
                    (dlgname,Spindle Error, opt=1)
                    (dlg,Failed to set spindle speed, typ=label, x=20, w=280, color=0xffa500)
                    (dlg,Response size wrong, typ=label, x=20, w=280)
                    (dlgshow)
                    M2
                O<test1> else
                    #<err> = 1
                O<test1> endif
            O<error1> endif
            ;check the crc16 of the response
            O<Crc16> call [4101] [#4100-2]
            O<error2> if [ACTIVE[] AND [[#4102 NE AND[#<crc>,255]] OR [#4103 NE SHR[#<crc>,8]]]]
                O<test2> if [#<count EQ 5]
                    (dlg,Response crc wrong, typ=label, x=20, w=280)
                    (dlgshow)
                    M2
                O<test2> else
                    #<err> = 1
                O<test2> endif
            O<error2> endif
            ;check that the request didn't have a bad crc
            O<error3> if [ACTIVE[] AND [#4101 NE 0]]
                O<test3> if [#<count EQ 5]
                    (dlg,Request crc wrong, typ=label, x=20, w=280)
                    (dlgshow)
                    M2
                O<test3> else
                    #<err> = 1
                O<test3> endif
            O<error3> endif
        O<loop1> while [#<err> EQ 1]
        ;pause to give time for the rs485 vfd comms to complete
        G04 P0.02
        ;now reqest for the vfd response
        #4000 = 2
        #<w> = 0
        O<wait> do
            G04 P0.01
            #4100 = 0
            M66 H38 Q4000 E1 R4100 D10 ; request the response data
                #<size> = [#4100]
                #<i> = 0
                O<print2> repeat [#4100]
                    (print,#<q,0>)
                    #<i> = [#<i>+1]
                O<print2> endrepeat
            O<test> endif
            O<test> if [#4101 EQ 0]
                O<Crc16> call [4102] [#4100-3]
            O<test> else
            O<test> endif
            O<error2> if [ACTIVE[] AND [[#[4100+#4100-1] NE AND[#<crc>,255]] OR [#[4100+#4100] NE SHR[#<crc>,8]]]]
                O<test4> if [#<w> EQ 5]
                    (dlgshow)
                    M2
                O<test4> else
                    #4101 = 1
                O<test4> endif
            O<error2> endif
            #<w> = [#<w>+1]
            O<test> if [ACTIVE[] AND [#<w> EQ 5]]
                (dlg,Response timeout, typ=label, x=20, w=280)
                (dlgshow)
                M2
            O<test> endif
        O<wait> while [#4101 NE 0]
            (print,Wait loops=#<w,0>)
        O<test> endif
    O<SetSpindleSpeed> endsub
    CRC16.sub
    Code:
    ; function to calculate the modbus crc16 of a buffer; takes 2 input parameters
    ;   1. start address of the buffer
    ;   2. count of bytes in buffer
    ; returns the crc16 value
    O<Crc16> sub
      #<start> = #1
      #<count> = #2
      #<crc> = 65535
      #<i> = 0
      O<Loop1> repeat [#<count>]
        #<crc> = XOR[#<crc>,[#[#<start>+#<i>]]]
        #<j> = 0
        O<BLoop> repeat [8]
          O<if1> if [AND[#<crc>,1] EQ 0]
            #<crc> = SHR[#<crc>,1]
          O<if1> else
            #<crc> = XOR[SHR[#<crc>,1],40961]
          O<if1> endif
          #<j> = [#<j>+1]
        O<BLoop> endrepeat
        #<i> = [#<i>+1]
      O<Loop1> endrepeat
      O<Crc16> return [#<crc>]
    O<Crc16> endsub
    I have been meaning to write this all up properly and publish on a website, but I haven't had the time. I am also not sure if there is enough interest to make it worthwhile.
    Cheers
    Simon
Page 2 of 3 123
  1. Output a signal on a pin
    By wentbackward in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-04-2014, 08:24 AM
  2. 1.6V-3.0V random signal voltage parallel signal from output – Any advice?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 11-12-2009, 11:36 AM
  3. Input/output signal on 0M-C
    By padobranac in forum Fanuc
    Last Post: 10-28-2008, 03:49 PM
  4. No Output Signal
    By tz1238 in forum Machines running Mach Software
    Last Post: 01-27-2008, 09:57 PM
