585,951 active members*
4,129 visitors online*
    Dec 2014
    35
    UC300 ETH-UB1
    Hello Gents
    What is this 5V port used for on this UC300 ETH-UB1 board?
    Is this to power the ENABLE terminals on the DQ542MA stepper motor drivers?
    Using the X axis as an example, I connected the stepper drivers as follows:
    XS+ to PUL+
    XS- to PUL-
    XD+ to DIR+
    XD- to DIR-
    I have not powered the board up yet,through the 24V power supply, so do not know yet, if there will be 5V available at that terminal on the board? Or must a 5V DC power supply be connected to this port?
    Regards
    Craig
    Re: UC300 ETH-UB1
    You can use it to power anything that needs 5V, up to 500mA.
    Do NOT connect a power supply to it.
    Dec 2014
    35
    Re: UC300 ETH-UB1
    Hello Gerry
    Thank you for your response. Pity that this 5V terminal, is not enough power for the proximity sensors.
    So it could be used to ENABLE the stepper drivers, if required to?
    Regards
    Craig
  1. UB1 - UC300-ETH - UCCNC not dancing yet
    By rcmcdee in forum UCCNC Control Software
    Last Post: 09-07-2018, 02:20 AM
  2. UC300 ethernet trouble
    By arachid in forum Controller Cards
    Last Post: 06-15-2018, 04:40 PM
  3. UCCNC and UC300 disconnecting
    By nicubila in forum UCCNC Control Software
    Last Post: 11-11-2015, 11:27 AM
  4. UCCNC & UC300
    By camivic in forum UCCNC Control Software
    Last Post: 10-27-2015, 08:45 PM
  5. UC300 interface
    By bickius123 in forum News Announcements
    Last Post: 09-19-2013, 07:44 AM
