586,013 active members*
3,781 visitors online*
    Jul 2007
    6
    Plastic as the mold material
    newbie here to vaccum forming... I was wondering if I could use machined hdpe as a mold medium for short run jobs using petg or would it melt?
    Jun 2007
    49
    Should work fine but sharp corners may eventually round off a tiny bit. It may also warp somewhat from getting heated on one side,.. depends on the shape?
    Nov 2004
    21
    Plastic mold material?
    Do you want to use the plastic mold forms because you have access to a bunch of big chunks of material?
    Otherwise there are a number of materials that would be as easy to machine, aren't very expensive, and might not require the experimentation to make sure they work.
    Jul 2007
    6
    yes I have some scrap material laying around collecting dust… I really don’t do that much vacuum forming maybe only once a month.
    I’m make mostly flat .25 inch dies
  1. Engraving Plastic Sign Material
    By Dingo745 in forum Engraving Machines
    Last Post: 08-18-2007, 12:39 AM
  2. Making a positive mold from a negative mold - how?
    By SRT Mike in forum Moldmaking
    Last Post: 03-29-2007, 10:30 PM
  3. Mold material for tinted PC (Makrolon)
    By GalaticDan in forum Moldmaking
    Last Post: 02-21-2006, 02:28 AM
  4. high performance plastic - bearing material
    By Chris D in forum Glass, Plastic and Stone
    Last Post: 09-03-2005, 12:43 PM
  5. Plastic Sign Material - Where to purchase?
    By edbo68 in forum DIY CNC Router Table Machines
    Last Post: 04-27-2005, 04:59 AM
