585,573 active members*
3,516 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > EX1104 TURRET CLAMP/UNCLAMP SENSOR ERROR or OVER 1SEC
    May 2020
    Unhappy EX1104 TURRET CLAMP/UNCLAMP SENSOR ERROR or OVER 1SEC
    HI, Good Morning,
    i need one help.
    EX1104 TURRET CLAMP/UNCLAMP SENSOR ERROR or TURRET CLAMP/UNCLAMP OVER 1SEC
    This alarm 15 to 30 min one time showing.we can't run continue production, (after mco this week only start production( cnc turning lathe).
    Machine model = V TURN NP16
    FANUC SERIES OI-MODEL F
    Please anybody help ?
    Thank you
    Dec 2009
    952
    Re: EX1104 TURRET CLAMP/UNCLAMP SENSOR ERROR or OVER 1SEC
    as i know the clamp/unclamp of turret is hydraulic, it measn that your system of fluids is getting jammed and the process of the unclamping and clamping of the turret is taking longer as when the machine was new.
    Causes can be in the hydraulic system or in the mechanic of the turret.
    in this case the easy way is too increase the timer until the clamp/unclamp sequence is done.
    as i do not have the ladder ,i can not tell you what is the timer number for that alarm, but should be 1000 in the timer page
    May 2016
    526
    Does the turret release within 1 second may be wise to remove sensor check it's working and clean it
  1. Replies: 26
    Last Post: 03-02-2023, 11:25 AM
  2. Replies: 2
    Last Post: 07-07-2016, 01:07 AM
  3. Replies: 2
    Last Post: 10-08-2013, 09:35 PM
  4. VM1 spindle clamp/unclamp error
    By BSF in forum HURCO
    Last Post: 02-15-2010, 02:19 PM
  5. turret clamp sensor malfunction
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-03-2007, 05:47 AM
