Feature:
The structure design of the whole set of equipment is reasonable,compact and beautiful in appearance; the world's advanced and mature technology and configuration system are adopted to ensure the equipment has good and stable accuracy. It has very high stability and is suitable for continuous production and processing.
Specification of eaak desktop waterjet cutter
Model EK6060
X Y axis Working size 600mm*600mm
Z working height 150mm
Max Pressure 420Mpa 37kw UHP pump
Control accuracy 0.01mm
Cutting accuracy 0.1-0.2mm
CAD/CAM software AutoCAD,ArtCAM
Repositioning Accuracy 0.05mm
Max cutting thickness 100mm(depends on materials)
Max. moving speed 5000mm/min
Power supply 380V 50Hz
Environmental temperature -10-50°C
Control system Ncstudio (Shanghai) software IPC controller
Drive motor Japan Yaskawa servo drive motor
