585,762 active members*
4,355 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > Home Switch setup ESS G540 and Mach 3
Results 1 to 2 of 2
    Nov 2007
    980
    So I'm feeling so dumb right now as I have numerous machines with homing switches setup with no issues. Unfortunately they're all parallel port machines and the one I'm trying to setup is the new ESS-G540 and Mach 3 machine. Do I not setup the homing ports and pins the same way? I'm using 3 normally closed (mechanical) switches and wiring them all to port 1 and pin 10 (position one on the G540). Whenever the switch is activated, it sets off the E Stop and doesn't finish homing. It also lights up the 3 home leds in Mach 3 so I know the communication must be correct. Is this an issue where the ESS needs to have a setting changed to allow the Homing to continue after hitting the first switch? Or am I still forgetting to check or uncheck something in Mach 3?
    I also have a touch-plate input that works correctly (the digitize led lights up in Mach 3 when activated and uses port 1 pin 12 (position 2 on the G540).
    Thanks so much for your time-
    Dave->..
    Nov 2007
    980
    Re: Home Switch setup ESS G540 and Mach 3
    Ok, so just for anyone in the future looking for this same issue, turns out, I was supposed to be using the G540 XML file from the Warp 9 website. I already had that G540 XML and just never loaded it! Worked like a charm. Thanks to Andy over at Warp 9!
    Dave->..
  1. MACH 3, Warp9 smooth stepper, Leadshine mx4660 Limit switch home switch woes HELP
    By cabinman in forum Mach Software (ArtSoft software)
    Last Post: 01-14-2018, 08:26 PM
  2. Gecko G540 Limit Switch Setup...
    By storm2313 in forum Gecko Drives
    Last Post: 12-14-2012, 12:26 PM
  3. Limit/Home Switch setup
    By StuartC in forum Mach Mill
    Last Post: 06-11-2011, 12:50 PM
  4. Optical home switch wiring to G540
    By mhackney in forum CNC Machine Related Electronics
    Last Post: 01-19-2010, 02:31 AM
  5. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
