585,722 active members*
4,392 visitors online*
    Aug 2008
    403
    mach4 lathe issue
    I run a program when it gets to the end M30 % It rewinds to the top of program .If I hit cycle start it wont run Mach is frozen .I have to shut Mach down and re-start the software to run the program again . Has anyone experienced this before and what did you do to fix it ? Thank you.
    Aug 2008
    403
    Re: mach4 lathe issue
    ENDED UP BEING A SOFTWARE ISSUE NEWER VERSION FIXED THE PROBLEM.
  1. SolidCam to Mach4 Lathe PP arc problems
    By Azalin in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-19-2019, 08:34 PM
  2. Mach4 Help Needed: Potentially Paid Mach4 & CNC Consulting
    By rappinadam in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2018, 06:49 PM
  3. Mach4 lathe questions
    By CS900 in forum Mach 4
    Last Post: 08-13-2015, 11:12 PM
  4. PP for the slant pro lathe issue
    By LeeWay in forum Tormach PathPilot™
    Last Post: 07-09-2015, 01:54 PM
  5. Issue with my Cummins Lathe...HELP!!
    By azcarbum in forum Mini Lathe
    Last Post: 03-03-2007, 03:58 PM
