585,573 active members*
3,498 visitors online*
    Nov 2004
    239
    Change Gear Needed
    I have a Birmingham NSL 19X60 lathe. Previous owner crashed it and tore up one of the change gears. I'll give overall details and can provide more specific details where needed.
    I'm not a gear expert so I'll post what I think I figured out.
    132 teeth
    total width of gear 19.05mm
    Pitch circle diameter 198mm
    outside diameter 201mm
    MOD 1.5mm
    Total depth of tooth 3.375mm
    Center bore can be whatever you need to cut the teeth with. I can finish machining the gear. Just need the teeth done right.
    I can provide pictures of the old gear.
    Re: Change Gear Needed
    Hi Shanghyd,
    My father owns a factory for gear manufacturing factory located in Taiwan for over thirty years.
    If you still need help, send me the sample or photo.
    Dec 2021
    31
    Hey,
    We are a manufacturer specializing in the production of mechanical equipment tools. Since our establishment in 2007, we mainly produce DRO, grating ruler, magnetic grating ruler, and we also supply various types of CNC machine tools, which may be able to help you, welcome to use Whats Contact me, or email me [email protected]
    Dec 2021
    31
    My Whats number is +8613528773691
  1. Change gear help
    By kylealastair in forum MetalWork Discussion
    Last Post: 06-07-2017, 05:14 PM
  2. Norgren Gear Change Solenoid - Gear Change Issues
    By JMFabrications in forum Haas Mills
    Last Post: 05-08-2015, 08:05 PM
  3. gear change
    By bjh91846 in forum Haas Mills
    Last Post: 03-19-2013, 04:34 PM
  4. Gear change pgm? How to handle
    By tubeguy in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2011, 02:37 AM
  5. Having trouble with vf2 gear change
    By Kenneth434 in forum Haas Mills
    Last Post: 10-13-2009, 03:21 AM
